RPMLegends18
Hi guys,
I having been thinking about doing the Magnum head swap onto my 318, the block has a casting date of 12/27/1968 or maybe the 12/28/1968. Anyways its a 68 block. I have been reading tech archives and many things before I try and attempt this project but then I was reading one archive that states this," The lifter bosses in a roller block are approximately 0.40” taller than a non-roller block. Since the roller lifter is much taller than a standard hydraulic, the taller boss in necessary to keep the oil holes covered at max lift. Otherwise you will have little or no oil pressure. The lifter bores *could* be bushed taller, but that is getting a little more involved than most guys want. Retrofit roller lifters ARE available but are kind of expensive. CAT has listed retrofit rollers on their site, but are not yet available." And my guess would be that my block is not a "roller block" at least I dont think. I am not too familiar with all that. The cam that is in it is a MP P4120231 which is a hydraulic flat tappet cam. It also came with MP lifters.
I am pretty sure the block was decked, but not sure if it was zero decked. It was a 340 crank, stock rods, and flat top pistons. The tops of the pistons are pretty close to being flush if I remember correctly, I know that sounds pretty stupid... This wasnt a performance build, but I would like to get a little more HP out of it.
So my two questions are; one, will my block be able to support this without having the lifter bores bushed higher. And two, is my setup going to hold up...like the lower end and pistons? Its a street car, that after going to a couple drag races, I would like to take it down the track every now and then and get some decent passes. I read the 400 HP build with Magnum heads on a 318 and that got me really interested. So those my questions and thank you for reading and for the possible help.
Thanks,
Ryan
added** the block has also been cleaned up to .030
Thanks,
Ryan
