From magnumswap.com
Intermediate Shaft
It is very important to use the correct intermediate shaft (the shaft between the cam and the oil pump, the cam gear is on this shaft.) The stock intermediate shaft is designed to be used with a hydraulic roller cam (steel), while almost all stock LA shafts are designed for flat tappet cams (iron). A steel cam will wear away an iron gear and vice-versa. This can lead to engine failure.
