moparman9
Considering a magnum swap into my 71 Dart. I have access to a complete running 1992 Dakota with a 5.2 MFI. Looking at the wiring diagrams, it appears that all the MFI system needs to use most of the Dakota's underhood wiring is to splice a power wiring from the ignition switch that is hot in run and start, a fused power lead hot at all times, and ground from the Dart to the Dakota wiring. I would use the original wiring in the Dart for lights, wipers, etc. Is this pretty much it or have I missed something? I know I will need an electric fuel pump and also need to notch my 727 bell housing for the crank sensor , change the flex plate, and install an o2 sensor, but it seems pretty simple. Is there any thing I am missing?
