03JeepJeep
It's a hoot!
I love the build! Are you running comp rockers and stock length push rods?
Damn-just noticed where you harvested a hood for $50-that's awesome-wish I could find a deal like that.
Thanks for the info! Looks like the builds coming along nicely!
You’re right. It looks pretty dang dood without a bumper! Maybe fab up a custom valance to fill the hole? I’ve thrown that idea around some for my Duster but haven’t done anything about it yet. I personally was thinking of something similar to this mustang.Got her running and driving finally! The new converter is a world of difference, so happy I made that leap. Happy to report no leaks thus far!
I had a couple issues early on chasing noises, one turned out to be a dragging caliper that needed bleeding, and another was the driveshaft loop back a hair too far slightly rubbing the shaft on big dips. The Firm feel front sway end links are also rubbing on the QA-1 strut rods so the sway is currently unhooked. Have to sort that one out some how.
I am kind of liking the bumper less look, so don't know if it will go back on right away.. I also need to dial in the front ride height, its a bit uneven from side to side.
The dart bumper sticks too far out in the middle to fit the Duster well but I’ve heard the 67-69 Barracuda bumpers are a lot straighter across and might fit to the body better.ah yeah that looks great! I wouldn't even mind if the slimmer dart bumper fit. Might have to try and find one at the J yard and see if it works.
I am waiting on some parts so I decided to finish up some odds and ends I have been wanting to work on. First up was the steering coupler.
Some old *** grease in there, more of a tar than a grease really haha
Old seal (that did nothing) vs new seal
Before some wire brush degreasing action
and after:
Some light wear on the inside from the shoes
New paint, new grease and new clip ready to go once I get the K frame / steering box back in:
And finally, I hooked the 5th and hopefully final gauge: trans temp
Did you put Chevy gauges in?
I’m sure it’s the same here, but cops are less likely to notice that vs Michigan. Michigan cops are way more likely to have some car knowledge hahaIn Michigan if it came with a bumper, running it without will get you a ticket.
