megacab
Leglhi
Also found the reciept for the mains.They measured .004-0043.Whats max on these?
Thanks Moper.I'll get on that.Think i'll have to remike everything,or should i be ok with the .001 oversize knowing that i miked everything a month ago,and that putting these in will bring it into specs?Thanks again.Have to get this thing ready for the Pinks All Out in September so we can keep getting some Mopars in there.
I'm curious why they said to leave the windage tray out? I have a custom pan that holds 8 quarts and it uses a windage tray on my 415 stroker. I believe in the small block stroker book he mentions not using a windage tray. Thanks for the info. Jaysonill try to get some pics for you.I have a high volume pump and milidon 8 qt pan with their pick up tube ect.i had a windage tray but discussed it with Ryan at SD and he said leave it out.I did.And the pressure never drops below 35-40 at idle.Of course idle is 1200
