Manifold gaskets
Peter L
Active Member
Ontario Canada
Quick question guys. Looking at pictures of exhaust manifold gaskets for a small block. What are the two small keyhole shaped gaskets used for?
Thanks, Pete.
Air injection lines to the exhaust manifold on pollution-controlled engines that use an air pump.
You do mean these, right?
Yes. Thanks! Been a while since I worked on a small block.
P.S. Does coolant run through the bolt holes like it does on the big blocks? Do I need to drain the rad?
