hotrod426
From a 1976 duster, so it has the key in the colmun with key release button a steering column with keys both door and trunk cylinders the keys work all lock cylinders, and a bottom cover in black. The column has a power steerin connector and firewall penetration cover. The only negative that i see is the harness will need to be replaced the turn signal switch has been removed. Asking $250. Shipped in lower 48.
