Just a question about the up and down play of the pitman arm shaft on my 68 dart with factory manual steering. If I adjust the jam nut and screw at the top of the steering box, will it take the up and down play out of it? I replaced the idler arm and noticed the pitman arm shaft has some play up and down, it moves up and down when you turn the wheel also.
