Manual to Power steering setup '66 Dart
I have a complete, in good working order power steering setup from a 1974 valiant with a 318 that I parted out. Everything is in good condition, no leaks. I have the pump, brackets, lines and steering box. Everything needed to convert to power steering. $150 if your interested
mopar%20parts
You will need a Power steering column, from a 1966 ONLY, 67 + UP are different, plus you will need a P.S. pump w/ 273 V8 Engine brackets, or if your engine is a slant six, yopu will need those brackets
MOPAR CHARLIE
It's a 318 engine but I can make brackets if needed, the big problem is steering box and i guess the steerig column, hoses and a pump I can get from anywhere. Do I need another pitman arm?
What's the diffrence between a 66 and say 67 column?
