Manual trans pedals. What year A body interchanges?
Kern Dog
Build your car to handle.
Granite Bay CA
Hello, all. A few years back I got a parts stash from a guy that was into the 63-66 Valiant and Barracuda cars. He was buying up stuff to build a 340, 4 speed. 8.75 Valiant convertible. There are some parts in the collection that may or may not be correct for the project.
I have what looks like a 67 and later brake and clutch pedal assembly. It has no rubber pads but the frame "cage" looks almost the same as the A/T setups I have here for the 67-76 models. I am asking if these interchange for all years. The early setups seem to NOT have a recess in the center for the collapsible steering column. Otherwise, they look identical in dimension.
So, the question is....Do the 67 and later pedal assemblies also fit the 63-66 cars?
Thank you.
No offense to BB66cuda, but NOBODY else has insight here? Over 70 views and one opinion?
Thank you. They are physically the same size with bolt holes in the same places. The only difference that I can see is that the later setups I have here have a recess below where the steering column sits.
