I have the Cheetah and MVB with reverse pattern, no problems at all. That's what was in it when I bought it last year. I am in the process of replacing the T-handle with a pistol grip. Got it roughed in so far. Everything has seen some "patina" for sure and will be getting cleaned up, painted, etc.
I will probably shorten up the upright a bit yet. Also trying to figure out a nice way to run the wires for the line lock.
I know it is off subject but I saw a shifter with a slot milled in the front with the wire glued into it. You will never even notice it. Just need a machine shop to do it unless you are a ninja with a grinder!
