My 73 340 Duster has a TA reverse pattern manual valve body, I use a B&M Pro Stick for a shifter. From Neutral i pull back on the shifter and holding the trigger it goes into 1st gear....pull back on the shifter ...in 2nd...and pull shifter and holding trigger I am in 3rd.....now as I slow down I can bump the shifter forward to downshift....Or as I stop I had hold the TRIGGER and move the shifter straight from 3rd gear into Neutral ...not stopping in 2nd or 1st....and it has a Reverse lock out.....
Pretty simple
Pretty simple
