straightlinespeed
Sometimes I pretend to be normal
So I've been stumped for the past couple weekends trying to figure out why my map and glove box light do not turn on with out my head/park lights being on.. This is on my 71 Scamp.
First off I do not have stock wiring. I installed the EZ Wiring kit last winter. I used the stock schematic to help get a guideline how it should be done, based off of the original wiring. I will however tell you how I have my car is currently wired, I hope you can follow along and it makes sense, oh and I made a rough schematic for you to follow along. So here we go.
1) 12V + from the fuse block, over to the passengers side then splits going to one terminal on the map light and to the glove box light
2) Out of the second terminal on the Map Light to one terminal on the Map Light Switch (MLS)
Ok bear with me here since #3 is a little more detailed.
3) The other terminal out of the MLS goes to a wire splice which contains 3 wires into 1 wire. 1 wire goes to Drivers side door switch, 1 wire goes to the passenger side door switch, 1 wire to the MLS. Then 1 wire to the HLS to the D terminal.
Now if I followed the stock schematic correctly this is how it should be wired, but I just dont get it. I figured I should be able to turn the Map Light on or open the Glove Box at anytime and the lights would work. Any help would be appreciated, Thanks
