Dizzydean
I did the front disc swap a while ago and am now getting to the master cyl. This is the one called for to replace the all drum. So far the only positive is it bolts up. Do I need to replace the plunger? Is this even going to work. Ive had it on the shelf for a while so no returning it. Second is there a way to disconnect the brake pedal. The 50+ year old pedal isn't matching everything else I'm cleaning and painting.
