Master cylinder hose fitting
yellow rose
Overnight Sensation
Central Washington
Working on a 73 Duster and the fitting on the master cylinder is busted. Can I A) buy a new one and B) will the damn thing come out without an hour fight?
TIA
YR
TIA
YR
Classic Industries has them for Midland produced boosters, grommet too. Try Napa, etc: Rock Auto has listing but out of stock.
I’m also wanting to make sure I can’t kill the MC trying to get the old fitting out. Do I just pry it out of there, or is there some other way to do it?
The MC is good shape and I just don’t want to replace that if I don’t have to.
TIA
YR
TIA
YR
Pry it out- screwdriver, channel locks. Use metric ones!!
Ok,if the broken piece is still in the rubber grommet , grab it as best you can maybe with vise grips then spray the rubber with plaster and wiggle it out. If it fell inside, not much you can do to remove it. Just put a new valve in it and let it roll. Maybe a picture would help?
Pictures man!! ... pictures...
Break booster!!???... Is this car for your wife??... wait a minute you said she had no problem using a rag clutch so definitely this isn't for her....
That is not a "plastic hose fitting." It is the check valve for the booster. In other words you need to to scare up the proper device.
I need to replace the fitting or valve where the vacuum hose hooks up. It the fitting in the booster.
You can get them at your local parts store. I belive they are in the help section. I just replaced the one on the Duster recently. I got the gromet and the check valve at Oriellys.
