master cylinder?
388dart
Does anyone know if there is an aluminum 4 bolt master cylinder for front disc brake, rear drum cars? A-body. A part number would be most helpfull - if there is.
Yes, there is. You won't like the price. It is a billet aluminum master cyclinder by SSBC. I bought mine through Summit. It was cheaper then direct from SSBC. The Summit part number is SSB-A0471-5 price was 369.95 in July of 2007. It works great and is nice looking. Good luck.
i do know that wilwood makes a large number of alum. masters. try there web sight for best application
terry
i just did this install. but this is a 2 bolt mc
i got a alum m/c off a late 80's 5th ave at the bone yard--it looks new.
fabbed a chunk of 3/8 aluminum for the adapter plate . very easy .
ran 1 new brake line to the prop valve.
i think the whole project cost me around $26.
the brakes work great !
Yep You Can Do It On The Cheap, I Used An Mid 80's Dodge Truck 2 Bolt Alum Master Cylinder, Fabbed An Adapter[ Very Simple] Didnt Change Proportional Valve And I Have Manual Disc Brakes....works Just Fine...........piss On All That Hi-dollar Crap They Just Want Your Money....
