[SOLD] Master Power Brakes Front Disc Brakes
Fast01
Farmingville, N.Y.
I have a used set of Master Power Brakes front discs I took off my '68 Barracuda. They were removed because I switched over to a Hemi Denny front end which uses Mustang II stuff. I have the calipers, pads, cross drilled and slotted rotors, brake hoses and spindles. No master cylinder or booster. It should also be noted that the spindles the brakes are mounted on have been modified for a rack and pinion front steer arrangement and cannot be used as a bolt on as they sit now. They will need a new bolt-on steering arm and need to have the modified arms ground off as they are welded on. These are located on Long Island, New York and I'd like to get $350 plus shipping.
