MATS 2011 Killer Bee's Pics and Vids
Geometry is simple...Always remember this and you can never go wrong...
The angle of the dangle is proportional to the heat of the meat.......
You young ones might take a while to figure it out though......
Now the way I heard it...the mass of the *** was also factored into the equation.
I ran 112.10 up to a 112.66. with 8 runs between those numbers.Maybee I screwed up.I went up 2 jet sizes on both primary and secondaries from what I run close at sea leavel.Did I go the wrong way??mark
those speeds could have been the results of the change in wind direction....
yea because at high altitude there is less air... so it gets richer... there for you want to down jet to correct your AFR...
