805moparkid
Slant and AFX Guy
so what is the max rpm for a stock bottom end that has been balanced and has ARP rod and main bolts/studs?
225 or 170? Piston speed at a given RPM would be significantly different between the two, although I believe the piston weight is similar. That said, I would think 5000 would be a practical limit on a 225 if you expected any sort of reasonable street life. Honestly, port size will probably limit breathing at or before this point. These engines were never designed to be high RPM, high flowing deep breathers.
I'm not sure if there are any dimensional stability/resonance issues with the cranks, but below 5000 these shouldn't be too big of an issue.
Hey Kid,I am just quoting what I have read,I am learning about the /6...
Are you not the /6 Guru?...LOL
TXDart
You will be before you are my age,aching 50...LOL
The little sumbitches will twist till a rod comes out the side.
lol i know and i want to be just before that...
LOL,love that answer !!rayer:
thinking f shot peening the rods and the bottom end balance would be to .25 of a gram...
anybody?
Don't bother with the balance job...get the weights close for each cyl.
I didn't balance mine on the advice of my machinest and have no issues.
Balance and smoothness
An inline six engine is in perfect primary and secondary mechanical balance, without the use of a balance shaft. The engine is in primary balance because the front and rear trio of cylinders are mirror images, and the pistons move in pairs. That is, piston #1 balances #6, #2 balances #5, and #3 balances #4, largely eliminating the polar rocking motion that would otherwise result. Secondary imbalance is avoided because an inline six cylinder crankshaft has six crank throws arranged in three planes offset at 120°. The result is that differences in piston speed at any given point in rotation are effectively canceled.
An inline four cylinder or V6 engine without a balance shaft will experience secondary dynamic imbalance, resulting in engine vibration. As a general rule, the forces arising from any dynamic imbalance increase as the square of the engine speed that is, if the speed doubles, vibration will increase by a factor of four. In contrast, inline six engines have no primary or secondary imbalances, and with carefully designed crankshaft vibration dampers to absorb torsional vibration, will run more smoothly at the same crankshaft speed (rpm). This characteristic has made the inline six popular in some European sports-luxury cars, where smooth high-speed performance and good fuel economy are desirable. As engine reciprocating forces increase with the cube of piston mass, inline six is a preferred configuration for large truck engines.[6]
7000 every pass crank not balanced.
what rods and pistons if i might ask?
My butt hole starts to really tighten at 6400.At 6800 its tighter than a frogs butt.I really feel over 6500 on a 225 is a waste.Guzzi Mark
