Judge Mills
1971 Plymouth Duster
will I be able to run the car with the slip yoke pressed all the way in?
The reason I ask is because is this: Originally a slant six 71' Duster, now a 318 with 904... Using the same driveshaft...
Now I converted the rear end to a Ford 8.8...
The driveline will work if i can drive it with the slip yoke pressed all the way in to the tailshaft.
The reason I ask is because with the old rear end, the slip yoke was pulled out a little bit when resting on it's wheels... Does the slip yoke move in to the tailshaft as the suspension is compressed?
Thanks for the help!
