Measurement Needed
GaryS
Ponder, TX
If anyone has a 318 block mated to an automatic transmission, I would greatly appreciate if you could measure the dimension from the center of the front mounts to the center of the transmission mount.
I'm trying to establish the location for a transmission crossmember on a custom chassis.
Thank you!
I think the mount spacing should be the same...but it will be a 727.
