SpeedracerX
Still on this side of the dirt member
Awesome job.. the inner fender replacement brought back memories...
wow not done yet ah
Well been sick for about two weeks so most of my holidays are a bust to work on this car. Felt decent today so went to the shop with the front fenders and did the final fit for the front end so its ready to be welded. Took some updated pics of the engine also since it stopped raining.
Got a few PMs asking about the engine specs so here goes, this was an older build before the stroker stuff became so much more available and cheaper. Sure not going to set the world on fire with it but it should be fun and I have another bullet waiting in the wings so .
389 CID stock balanced steel crank, decked, line bored, balanced and blueprinted block. Speed Pro 11.00:1 Forged pistons on (new) stock reworked rods.
906 fully ported heads 2.14-inch intake and 1.81-inch exhaust, one-piece stainless steel valves with hardened seats and 1.5 ratio crane gold roller rockers.
Ported edelbrock torker intake manifold with 1 open spacer
1000 CFM modified holley double pumper carb
Milodon oiling system
1 7/8 Hooker fender well headers
Engle hydraulic cam IN 517 EX 517 AD 288* CL 344 D@50 236 LC 107
Best Dyno run 467.3 CBT Lb-Ft @ 4700 457.4 CBHP # 5700
Oh and that's a modified ferd distributor to run with my old MSD 6A
could you give more info or even some pics of the modified distributor
Here are some close up pics of the Disturber, I will take it apart to see what has been done with it when I have some time. Oh and thanks for your condolences for my friend Darren, I sure miss the guy.
