In need of a Midland brake booster for a 73 Duster with front disc/rear drum. Midland has a clamp ring around it and Bendix has a crimped housing. Thanks and be safe out there, Jack
I have a booster I bought for my 69 Barracuda but turned out to be too big in diameter (8 1/2 - 9"). It has a clamp ring around it. Your mailbox is full so unable to reach you.
Thanks, I'll fix that. The booster you have will not work. Out the back of the booster the rod has to be a teardrop type (newer) plus needs to be disc brake.
I can't give up mine for rebuild right now. Don't want to cripple the old girl for weeks, especially during the summer. Leaking master into booster.
