chryslerfat
That is a 65 for sure. I have picked up a 64 last week and can see a few differences between the 2 that clues yours to be a 65.
Looks to be a 65............but......just may be a late production 64?!?!
Ma Mopar did some odd things.
didn't the 66 cars have the slimmer A/C unit and the 64-5 cars have the bigger, boxier unit?
Here is what a 64 looks like with factory a/c. In your Vin Tag M with a 3 under it is factory a/c, this is done when the car is ordered. However, the identical A/c kit could also be put in at the dealer but the VIN would not reflect that. Also to clear up some myths power brakes on all Valiants, Barracudas and Darts were done at the dealership. All power steering is factory. Hope it helps, what you have is a 65. I have a very late Barracuda it was built 2 days before the production run shut down. So my Barracuda emblems are like a 65 no long a at the end, I also dont have a Valaint emblem on the right rear trunk facia. No one knows when the change over took place, not even Gaylen. But I can say I have never seen a car built after May that had them.
..." <<<<Yes you can go form 13 inch to 14's;
14x4.5 small bolt pattern rims are cheap,
14x5.5 small bolt pattern rims are available,
but, not as easy to find, as the narrow ones.
"...If you like the car, buy it.
End thread/8)
