moper
Did you find out why the lobe went south? Your builder should be verifying lifter rotation, the spring are correct, and the pushrods and preload are correct during his work. Whomever starts it should not be rotating it much during installation, preoils it properly, ensures it fires immediately, and can run for the entire break in period without having to be shut down.
