I just noticed your other post here, just down a couple threads. Are you seriously looking into putting in a turbo, or just looking at options? If you're asking what headers to use with a BB in an A body then within barely 12 hours, switch to what cam would be good for a turbo build...?
I'm sure there are dozens of folks who'd want to offer advice, but just to save yourself some grief, do you know what you want out of the car? What's your hp, or ET expectation? Running a turbo will add significant cost to any project-even if you go with a cheap one off eBay that'll likely die inside of a year. Turbos require a pretty good bit of fabrication, and unless you have friends with those skills, that kind of work usually isn't cheap. You're also going to be looking at cutting holes in places they don't normally belong to route intercooler piping. Then start looking at bigger fuel system parts, and beefing up your trans, brakes, and chassis/suspension. Even a mild 400 with a modest build with 8-10psi will likely make enough power to start bending stuff and running other parts beyond their normal capabilities...
Just food for thought.
