yellow rose
Overnight Sensation
Though out of the spectrum, you can include the slant 6 heads in the "work the floor for more" approach.
Forgot about those.
The side of the guide and roof area near is so thin I don't even touch it.Forgot about those.
What kind of advice ?
Work the straight side ssr just off the seat to a more vertical shape than the buldge it is and at the last 1/3 from the top...ever so slightly lay it back and leave a lip, don't round the top of the ssr to the floor, you want a definitive steep ramp.
Thin the guide, shorten its height about 5/16 and grind the guide tail to mimic the set angle.
Open the rest of the bowl , keep it a little smaller than the seat, use the throat cut to guide you and leave an even .100 of throat cut for now, don't grind too much on dogleg side of bowl, go straight up from throat cut on straight side of bowl.
Hard to put it into words, so be conservative. Tall is good, laid back too far is bad that you cannot come back from.
Lol, I was about to post that, ...and Whooop! There it is!!Though out of the spectrum, you can include the slant 6 heads in the "work the floor for more" approach.
Agreed, except after hours of porting My case of "cold hand" wasn't even alleviated by a shop rag wrapped grinder, break-time!!If I had to port with an electric grinder, I'd quit. I use air, which is a pain in the *** but I get a much better finish.
Either way, you have to have some way to slow the grinder down depending on materiel, tooling and desired finish.
I almost never use a stone but I do have them. I always start with a carbide and finish with a paper roll.
Here's the thread with some instructions and terminology.
I wonder if same technique is same from 318 heads to x heads??
318 head porting for the average joe
that would be great, ive got a set of 308s i want to work onI'll be finishing a stage 2 308 and x894 head.
I'll see about doing a thread. Gotta have someone take the pictures or it kills my flow.
