joeboy
A) I ordered the milodon dip stick, yes, it goes in the hole in the left side of the block. It was easy to install...
B) The biscuit mount hits the plate... I chopped mine with a grinder. The driver side mount should have the bump facing the motor/TTI plate, the passenger side the bump faces the K-member, bump to the bottom.
My last post here has a few pics you can kinda see mine..
http://www.forabodiesonly.com/mopar/showthread.php?t=59806&page=3
or try here... TTI PIC.
http://ttiexhaust.com/PDF/Sheet3706FBP.pdf
