mini starter off v6 mag nose cone mod ?
I use a 95 Ram 2500 as the model. No changes needed on a 360, a 400, or a 440. Bolts right on.
It's all good, now we all know 96' has to be modified on stock three speed trans bell housing/360, but after mod ... It WILL work and work great. Been everywhere in it today. It's nice to be able to turn the car off and start it back up again 10,20,30,40 even a hr later without letting big starter to cool from headers
I got apiece of wood burning stove flu metal, " heat resistant" I'm using for a head shield. Saved a lot of this $$$$ , all kinds of ways to make it look nice, and save ton of money
Fairly certain it was the 96 magnum dakota starter i bought for my 318, and it is working great.
Fact: 96' Dodge Dakota SLT v6 Magnum / Mini Starter, will NOT fit stock 72 Duster trans housing unit, without two mods done to it. Period.
Fact: 96' Dodge Dakota SLT v6 Magnum / Mini Starter, will NOT fit stock 72 Duster trans housing unit, without two mods done to it. Period. Even if your block was grinded right by factory in 1972, and you didn't have to modify the top, you have to modify cone, or you can't bolt it down.
I believe 95 and older are the starters that bolt right in. I have put 3 of those in without any grinding
Well, I just did it. And guess what, it didn't fit your more than welcome to review my steps and pics I took and see for your self
Better yet I think your both high. You think I wanted to spend my day grinding a starter lmao here you go.... This is how far off the cone was...
Go take your starter off. And show me, like I'm showing you. You want me to do it all over again, but make a film ? I documented everything. My Duster, my family, know one else has ever owned it. I got the receipt from 72 and a spare bedroom full of parts, if I tell you it dosent, it dosent fit without nose job
Dang dude, relax.
The part number for the Dakota starters changed in '96. '92-'95 is a completely different part number (and is the same for v6 and V8's). So it could be the earlier ones fit just fine, you don't know. On top of that it's also worth noting that it could be a problem unique to your 3 speed bellhousing, because I bet most of the other folks have 4 speeds or auto's, and they're not the same. And finally, it could just be the pocket for the nose of the starter on your bellhousing just didn't get cast deep enough and others did, because crap happens.
So, thanks for sharing your experience, maybe it will help someone else that runs into that particular problem. But it doesn't mean other people haven't bolted them straight on with no mods.
I agree with above - David, what you did is cool and a great resource for someone who runs into the same issue - don't go turning this thread into a pissing contest over which mini starter does/fits what. You can now confidently say that some mini's need to be modified and you know exactly how to do it. ~it's all good :thumbsup:
Rockauto application list on starter for a 1994 Dakota V6 & V8 same part number.
This is a list of other vehicle that this starter should fit
Denso 2800136
DODGE B150 1991-1994
DODGE 1500 1995
DODGE B250 1991-1994
DODGE B2500 1995
DODGE B350 1991-1994
DODGE B3500 1995
DODGE D150 PICKUP 1991-1993
DODGE D250 PICKUP 1991-1993
DODGE D350 PICKUP 1991-1993
DODGE DAKOTA 1991-1995
DODGE RAM 1500 PICKUP 1994-1995
DODGE RAM 2500 PICKUP 1994-1995
DODGE RAM 3500 PICKUP 1994-1995
DODGE RAMCHARGER 1991-1993
DODGE W150 PICKUP 1991-1993
DODGE W250 PICKUP 1991-1993
DODGE W350 PICKUP 1991-1993
Please refer to catalog for application details.
Power Select /WPS 17466N
CHRYSLER 300 1965-1971
CHRYSLER CORDOBA 1975-1983
CHRYSLER FIFTH AVENUE 1983-1987
CHRYSLER IMPERIAL 1966-1983
CHRYSLER LEBARON 1977-1981
CHRYSLER NEW YORKER 1966-1982
CHRYSLER NEWPORT 1965-1981
CHRYSLER TOWN & COUNTRY 1965-1981
DODGE 330 1963-1964
DODGE 440 1963-1964
DODGE 880 1963-1964
DODGE A100 1964-1970
DODGE A108 VAN 1967-1970
DODGE ASPEN 1976-1980
DODGE B100 1971-1980
DODGE B150 1981-1994
DODGE B1500 1995
DODGE B200 1971-1980
DODGE B250 1981-1994
DODGE B2500 1995
DODGE B300 1971-1980
DODGE B350 1981-1994
DODGE B3500 1995
DODGE CB300 1980
DODGE CHALLENGER 1970-1974
DODGE CHARGER 1966-1978
DODGE CORONET 1965-1976
DODGE D100 PICKUP 1963-1987
DODGE D150 PICKUP 1977-1993
DODGE D200 PICKUP 1963-1980
DODGE D250 PICKUP 1981-1993
DODGE D300 PICKUP 1963-1980
DODGE D350 PICKUP 1981-1993
DODGE D400 PICKUP 1978-1981
DODGE D450 PICKUP 1978-1981
DODGE DAKOTA 1987-1995
DODGE DART 1962-1976
DODGE DIPLOMAT 1977-1987
DODGE LANCER 1962
DODGE MAGNUM 1978-1979
DODGE MIRADA 1980-1983
DODGE MONACO 1965-1978
DODGE P200 1967-1972
DODGE P300 1967-1972
DODGE POLARA 1962-1973
DODGE RAM 4000 1995
DODGE RAMCHARGER 1974-1993
DODGE ROYAL MONACO 1975-1977
DODGE ST. REGIS 1979-1981
DODGE W100 PICKUP 1963-1987
DODGE W150 PICKUP 1977-1993
DODGE W200 PICKUP 1963-1980
DODGE W250 PICKUP 1981-1993
DODGE W300 PICKUP 1963-1980
DODGE W350 PICKUP 1981-1993
PLYMOUTH BARRACUDA 1964-1974
PLYMOUTH BELVEDERE 1962-1970
PLYMOUTH BELVEDERE II 1965-1967
PLYMOUTH CARAVELLE 1978-1987
PLYMOUTH CUDA 1970-1974
PLYMOUTH DUSTER 1970-1976
PLYMOUTH FLEET SPECIAL 1962-1963
PLYMOUTH FURY 1962-1978
PLYMOUTH GRAN FURY 1972-1987
PLYMOUTH GTX 1967-1971
PLYMOUTH PB100 1980
PLYMOUTH PB150 1981-1983
PLYMOUTH PB200 1980
PLYMOUTH PB250 1981-1983
PLYMOUTH PB300 1980
PLYMOUTH PB350 1981-1983
PLYMOUTH ROADRUNNER 1968-1975
PLYMOUTH SATELLITE 1965-1974
PLYMOUTH SAVOY 1962-1964
PLYMOUTH SCAMP 1971-1976
PLYMOUTH TRAILDUSTER 1974-1981
PLYMOUTH VALIANT 1962-1976
PLYMOUTH VOLARE 1976-1980
RockAuto application list on starter for a 1994 Dakota V6 & V8 same part number.
This is a list of other vehicles that this starter should fit.
Denso 2800136
DODGE 1500 1995
DODGE B2500 1995
DODGE B3500 1995
DODGE 330 1963-1964
DODGE 440 1963-1964
DODGE 880 1963-1964
DODGE B1500 1995
DODGE B2500 1995
DODGE B3500 1995
DODGE CB300 1980
DODGE LANCER 1962
DODGE RAM 4000 1995
PLYMOUTH PB100 1980
PLYMOUTH PB200 1980
PLYMOUTH PB300 1980
that's all well and good - but it's $105 w/o a core - Dave took one out of a truck that I think he had just sitting around and, in a few hours with some patient work, he had a running car. Now we know one can be sourced out of a 97 & newer and be made it work - necessity is the mother of invention.
So for something that could have been purchased new, bolt on, for $75. Was this worth the labor? if so then great, you saved some dough!
I just thought that this was a very useful list for the next time that I go to the local Pull-a-Part to replace my dragging starter on my 65 273, and it might be useful for everybody.
Denso 2800136
DODGE 1500 1995
DODGE B2500 1995
DODGE B3500 1995
DODGE 330 1963-1964
DODGE 440 1963-1964
DODGE 880 1963-1964
DODGE B1500 1995
DODGE B2500 1995
DODGE B3500 1995
DODGE CB300 1980
DODGE LANCER 1962
DODGE RAM 4000 1995
PLYMOUTH PB100 1980
PLYMOUTH PB200 1980
PLYMOUTH PB300 1980
Wow, I just went to post the 2800136 part number and saw your post. I have to order one for my 68 360 auto. Should fit right in? Moper says its a fit, bolts right in. Been lots of info about the ones you have to cut plastic off as well as other tips to make them fit. I want a tried and true bolt with out trimming the terminal stud etc.
Hey every car is different, he did a great job on making it fit, Dam I broke two noses off on my 440 pretty much the same reason and then did almost the same thing he did. Good job showing us how to get er done.
