B bumnround Well-Known Member Joined Oct 25, 2008 Messages 311 Reaction score 3 Aug 29, 2010 #1 This winter when I swap the 273 for a 360 I would like to use a mini starter. Is a 3.9 v-6 starter the same as a v-8? Thanks.
moparsegura moparmaster Joined Mar 26, 2008 Messages 927 Reaction score 12 Aug 29, 2010 #2 yep, same thing. I took one off a 93 Dakota 3.9 and put it in my 69 383. 11.5:1 motor and it starts it great.
1 1wild&crazyguy Banned Joined Jul 11, 2009 Messages 7,751 Reaction score 239 Location Surrounded by mopar Aug 29, 2010 #3 ditto
ham_r_down01 Is Freak Nasty Joined Jan 27, 2010 Messages 159 Reaction score 5 Location MI Aug 29, 2010 #4 mine on my 340/904 had starter ring clearance problems.... die grinder to the nose cone solved that.... works great
inkjunkie Well-Known Member Joined May 24, 2009 Messages 17,413 Reaction score 3,083 Location ...... Aug 29, 2010 #5 Is this the starter that the terminals are very close, if not hitting, the side of the block? At least on a big block?
1 1wild&crazyguy Banned Joined Jul 11, 2009 Messages 7,751 Reaction score 239 Location Surrounded by mopar Aug 29, 2010 #6 just the big block.
moparsegura moparmaster Joined Mar 26, 2008 Messages 927 Reaction score 12 Aug 29, 2010 #7 Mine had some kinda adapter bolted to it to make the hot stud higher. I took it off and bolted it to the 383 with no problems.
ham_r_down01 Is Freak Nasty Joined Jan 27, 2010 Messages 159 Reaction score 5 Location MI Aug 29, 2010 #8 i forgot ive ran into this problem before, but if you have a 727 ive never had a problem
A AJ71DUSTER Well-Known Member Joined Aug 20, 2009 Messages 362 Reaction score 4 Location Michigan Aug 30, 2010 #9 I had to split the wires just a little bit where they bolt on to the studs on the starter, but other than that works great.
B bumnround Well-Known Member Joined Oct 25, 2008 Messages 311 Reaction score 3 Aug 30, 2010 #10 thanks guys
