Mini tub questions...
68383GTS
East Peoria,IL
I am mini tubbing my 67 Fastback Barracuda and I have a few questions.
Can I run a stock fuel tank? If so do I need to modify it?
Can I run the exhaust all the way out the back if I use the stock fuel tank?Or do I need a fuel cell or narrow tank to do this?
Thanks,Jim
Yes and yes. You will need a very skilled tubing bender to snake the pipes between the shocks, leafs and tank, but it can be done.
i got a 67 barracuda convertable & i'm going to tub it in aug. the gas tank depends on how big a tire u go with. i'm puttin on 29x 18 mickey thompsons & i'll have to run fuel cell. a good muffler shop will have no problems routin exhaust thru it. if u mini tub it & use a spring relocater kit u can keep your stock tank.
