Modifications to Offenhauser 1 1/2 carb spacer Thermoquad to Holley pattern ?
Brooks James
VET, CPT, Huey Medevac Pilot
Fruitland Park Fl
CORRECTION !! Spread bore to spread bore Was lucky to find This. Ill have to get the stock phenolic gasket for the base it overhangs. Looks like i will be pricing a grinder/dremel.and making a metal gasket
For the base. Yes,Semea like at lot of effort but its a 60-70s piece and im using as many era
Correct speed parts, as well as pieces that would have come off a Stock mopar.
My questions are:
1) should I hog out the marked area, will it create turbelence, if not will the extra plenum area help?
2) IAm going to leave enough spacer to have a center divider, to take full advantace of the dual plane intake
3) i have read that spacers can help, do nothing at all, or hurt performance
Im guessing that a spacer will help more with a single plane intake, not as much so on a dual plane ?
So I surmise that by not keeping / making a divider, i will change the flow charestistics of the dual plane.
4) my intake is a Chinese Air gap dual plane
Said to have a 1500-6000 sweet spot, stock magnum heads, street/strip cam, and Dougs 1 5/8 headers
Your experience ???
If you said that you havent fabricated a part to fit, you're a damn liar !!
Well, of course I've modified things. But I only modify things when I have to. What you have there does not need to be modified in the least in order to use it.
You slam me a a person and the things i do, and now your feelings are hurt ??
Not at all. I just called it like I saw it. I never "slam" you. I tell the truth. You just don't like it.
