Modified 1970 Duster - Show Quality
Reindeer
Senior Member
Illinois
I'd like to start another project - it seems I get more enjoyment out of building a car than driving it - I only had this car out 4 times last year - it needs to be driven, whether you take it to the track or just go cruizen. Let's get started - this car was originally a 340 Duster - 3 spd manual - bucket seats - black vinyl roof - same color, Rally Red - that was then - it's now a 416 cu in Stroked 340 making 502 hp and 522 ft pds of tq at 4000 rpm, with 9 to 1 comp - 750 cfm Mighty Demon - Edelbrock Air Gap - Edelbrock Alu Heads with extensive work by Shady Dells Speed Shop ( $5,000 invested in the heads alone ) - Straightline Performance custom grind hyd roller camshaft .555 int / .548 exh lift - .242 int / 250 exh dur at .050 - 1.5 rocker ratio - centerline 108.0 in / 116.0 exh - lobe separation 112 - installed at 106 - 4" Eagle 4340 Stroker Crank - Diamond Pistons - the list goes on and on - the motor cost over $15,000, that's with the heads - then there's a Strange Engineering Dana 60 under the car ( 4.10 ) - TSI 727 trans full manual reverse shift pattern with a 10" Turbo Action Converter - that's backed up with a Gear Vendors Overdrive turning the 4.10 to 3.55 ( I also have a 3.55 gear to make it 2.76 ) - for those of you who have read this far - I commend you - for I would have stopped when I saw how much money was spent on the heads - I don't expect anybody to give me what I'm about to ask for this car but here goes - $35,000 - send me a PM if you'd like more info or just shoot the poop .. Reindeer
it wont always take pics if there too big , but try to read slo and you will find go advanced under your post then click on that or look down sides for attachements
try to look for go advanced under your post a few clicks g/l it will let you go to browse and load a bunch up then tell us what there about load a few more so on and so on
More to Come
Many Thanks to WINSTONINWISC for telling me how to load my photos after I had already listed my ad...
Let's make this a package deal - the car as listed plus a matching set of rear wheels with ET Streets and a custom aluminum car trailer - $52,000
It's a new year (2014) and I'd like to find a good home for my Duster and Trailer - thinking of taking it to Indy this spring to see what it will bring at Mecum - send me a PM if you'd like more info on the car - Thanks in advance ...
