71produster
I got the torqueflite handbook read it twice and now I'm in the middle of doing some oil modifications !
I have Drilled the in and out of the of the oil feeds to 11/32" ,I had the front pump support modified to help out oil flow,I all so got the output shaft support modified with a roller bearing and seal.
I working on putting a roller bearing in the low & reverse drum now.
I all so put the 4 bolt spag in as well.
I used good used parts to do these mods.
I"ll take some pictures to show the mods that I have done.
Do you think these modifications will help out the life of my trans ??
Thanks for the help!!
