superdart
Shade Tree Tinker Gnome.....
Well, it started in this thread:
http://www.forabodiesonly.com/mopar/showthread.php?t=153229
But my modified 8.25 axle is finally back under the car. It has 1994 Jeep brakes, a 29 spline Dakota Trak-Lock, Dutchman Performance hybrid axles (thanks to Cass over at Dr. Diff).
We ran it on jack stands for a few minutes to let it free spin and to check the new brakes out. After that I drove it around the neighborhood just to give it a little shake down and make sure nothing drastic was going to happen.
I will admit I was nervous as hell that I was going to set up the gears wrong (never done it before). But, I took my time, did my research and double checked my work. No rear end noise so far. WOO HOO!!
I was VERY pissed that the LPW cover did not fit properly. The cap feet are scrapped and it's now just a heavy duty cover. I've owned it for so long they would not do anything for me. I also had to grind out the inside of the cover to clear the adjuster lock bolts...the LPW is anything but a bolt on unit, and I would not recommend it to anyone unless LPW can explain why nothing lines up.
