[SOLD] Modified Edelbrock MAGNUM RPM 7577
KnuckleDuster
Texas
This is an RPM Air Gap intake that TXDart (Martin) either modified, had modified, or bought before he passed away a little over a year ago. It has been modified to run a Thermoquad, or other spreadbore carb. It's very well done, somebody put a lot of work into this unique piece! I think he intended to use it on an LA block 360 with Magnum heads that he was working on. All my stuff is LA, so I really don't have a use for it, and would like to see it go to a good home. Other than the carb flange mod, it looks to be like new. Every bolt hole looks great!
All the ports are as cast, not gasket matched.
I will also include a set of Mr. Gasket 308G graphite intake gaskets, that were in the box. They each look like there is a little crush around the edge of and divider between one set of intake ports, but would probably work fine. They are dead soft graphite like Remflex.
Asking $325 including shipping and paypal fees to anywhere in the lower 48.
