Modified gauge cluster
Craig Burriss
Statesboro Georgia
I was originally planning on keeping the stock gauges in my Duster, but then I did an ammeter bypass, then the speedometer broke, and the fuel/temp gauges never worked to begin with. I don’t like having gauges thrown all over the car so I’ve decided to make it how I want it.
I haven’t started the operation yet but whenever I get over this flu it’s going under the knife (or Dremel).
From all of the pictures I’ve seen of custom/aftermarket clusters, everyone has 2 large gauges, and 4 smaller ones. For my plans I want 2 large and 5 smaller gauges. I ordered some matching Equus gauges and a close matching AEM gauge.
3-3/8” 160mph speedometer
3-3/8” 8kRPM tachometer
2” oil pressure
2” water temp
2” volt meter
2” fuel gauge
2-1/16 air/fuel wideband.
I wasn’t sure if I could squeeze all of them into the cluster but after doing some measurements, I think I can pull it off.
I plan on cutting out the original cluster face and replacing it with a piece of black plexiglass, cut to fit the gauges.
I’ll have to figure out how to ground the switches.
If you have any input or ideas I’m all ears.
That’s about how I did mine used a plastic board for backing then covered in a carbon fiber cloth.
Looks like it'll be tight in there....hope you can get it all to fit well.
Well i haven’t got the car street ready yet but all work good with the car idling lol. I did have to replace the fuel gauge as it stopped working with in a couple of days of putting it in but it was with in the warranty.
I would mount 1 or 2 of those gauges under the dash. It wont look out of place. Be awfully jammed in there the way you have it laid out. I know for me last thing I would want is a lot of wiring crammed in there. As mentioned, wiper and headlight switches?
Good luck
It’s almost done. I still have to do a few small things but everything works for the most part.
I think the fuel gauge is reading way lower than it should, and I have to touch up some of the paint I scratched while installing it.
Overall I’m extremely happy with how it turned out.
I was going to use plexiglass as the backing but it was too hard to cut with my barbaric tools. So I ended up cutting a piece out of the plastic storage tub that used to be behind the seat in my Ram, cut it to shape, bought a $12 amazon hole saw kit for the holes, then JB welded it in.
I ended up relocating the light/wiper switch to just below the cluster.
For the blinker indicators, I added two small bulbs into the now useless PRND21 area. Also wired the back lighting bulb for the PRND21 as the high beam indicator.
i think it looks good,my 70 dart has a different cluster,but when i get home i'm going to look at it & see if i can put something together similar to what you did.thanks for the idea friend
