i just installed the moog 7103 offset bushings to gain more caster. In the box came some large and small washers which the instructions say press into the ends of the bushing sleeves. My concern is that by pushing in the washers the upper control arm bolts will not have the load evenly distributed along there length but will have load concentrated on the two spots where the washers push into bushings. This will occur because in order for the washers to push into the bushing sleeves they are obviously smaller in diameter. The width of the washer where it pushes into sleeve is about 5/32". I am worried about the concentrated load wearing the shaft of the bolts prematurely. Should I be concerned about this?
