[SOLD] Mopar 1969 Small Block Engine Single Point Distributor
69KillerFish
Washington DC
Mopar small block single point distributor. Pulled from a running 1969 A-body. Shaft moves very freely. The part number is 2875 342 24 7. There is also the number 46 stamped in 2 places into the housing. Length of the distributor from shaft end to end is 10". The bottom exposed end of the shaft measures 2 7/8". The diameter of the housing is 3 1/4". Most likely it will interchange for many other small blocks and years. Needs a little cleaning.
Located in Wash DC. 20001, I am asking $75 + shipping.
