MOPAR 1970 440 Oil Pump Question
RoadRunner1970
Active Member
PA
I need to get an oil pump for a 1970 440-6 pack engine, any suggestions? Thanks Brian
Street, drag race, space shuttle, tractor pull? Can you give us a little hint on the desired application please? I don't know many mind readers.
not changing, don't have the original and having a hard time trying to find the original. Brian
The just get a Melling standard volume and be done with it.
What he said ^^. I thought you might have an oiling system problem. If it's all good then a stock pump is fine.
