challengersteve
You are buying a 1968 Mopar 727 Torqueflite Automatic Transmission for a 383HP application.
This is Mopar PK2892031 and is ASSEMBLY LINE CORRECT for all A B C Body cars that has the 383 HP engine.
This transmission has never been into and is from a parts car that was wrecked and parked with only a little over 60K miles.
The correct original higher stall torque converter is included as well.
I checked and I DID NOT SEE A VIN STAMPED INTO THE CASE but it is not a service replacement version as the date code is 2224 and 0050 (very early 1968 model year).
We cleaned and pressure washed the transmission and verified there are no cracks, no corrosion and no damage and clean fluid came out when drained.
This will be a perfect transmission to have rebuilt for your numbers correct 1968 Mopar showcar.
This will be strapped to a pallet and shipped truck freight or local pickup is of course welcome.
The trans and converter price is 450.00 plus shipping which should run between 275.00 and 450.00 depending on where you are. Local pickup is of course welcome.
I accept paypal and credit cards over the phone.
Thank you very much, Steve Schwietzer
