That is one gooooooodsounding littleblock :shock:
Btw did you see my post about cranks with almost the right stroke?
No I have not. Never been above the Mason Dixon line. I plan on keepin it that way.
Out here on the farm the wind gusts have me at about -40* . . I got a spare room whenever you wanna come North of the line ;) haha the cummins hates it!!
so what about a 3.79 stroke, 4.070 bore, K1 6.2" SBC rod and a shelf diamond piston? My math says it's a go, maybe next year :glasses7:
Sounds like it will be about .040-.045 in the hole at 9.6 deck.
any flow #s for those headsand do the 208s flow or help that much more than 202s
no just use a 6.25 rod instead of the 6.125 rod.Simple!a 3.79 crank is available for not all that much money
http://www.molnartechnologies.com/molnar-cranks.html
that just leaves the custom pistons unless there is some oddball chevy rod that would make this work with a piston intended for a 4"crank with a chevy pin.
