[FOR SALE] Mopar 727 SM Blk Transmission with Turbo Action Automatic Shift VB
dart540
south western PA.
Rating - 70%
7   3   0
Fresh Build 727 Transmission SM Blk with Turbo Action Automatic Shift VB Billet Low Rev Servo With HD Spring Acc Blocked Early Frt Servo With HD Springs Modified Oiling Mods Teflon Rings New Pump Gears Alto Clutches Red HP Flex KD Band Red Rev Band 3.8 Lever HD Band Strut Deep Steel Pan with Drain Plug Aluminum Frt/Rear Planets Stock Direct Drum 2600-2800 Stall Converter Netural Balance Wide Ring Gear
3yr Warranty
$1850 + Cores
Pick Up or Can Ship
Western PA
