dart540
Hello All just finished rebuilding the 904 trans has bellhousing notched for converter access,vent blocked and moved to rear,stock modified front drum with special spring to stop it unwinding on top end,5-thick blue racing clutches/steels,solid red racing kickdown band 1.375 wide,5.0 lever,HD band strut,lightened rear clutch,with 4-thin blue racing clutches/steels,extremely lightened sun gear,rear drum,low reverse band double wide red racing material,Turbo/action RVMVB with special spring to increase line pressure,low rev servo made solid,acc blocked,front wide servo two spring,4-pinion steel planets frt/rear,oil mods to case and internals,new pump gears,babbitt front pump bushing and teflon sealing rings, with deep steel pan.Case has transbrake connector hole with pipe plug if down the road you want to go that way.
$1450 Free Shipping in USA PM for pics/information/LOW GEAR SET ALSO AVAILABLE
Thanks Stan.
Thanks Stan.
