challengersteve
You are buying a pair of Mopar A Body Big Bolt Pattern Axles for a 7 1/4 Rear End.
These are from a 73 Duster with the 7 1/4 differential and factory disc brakes. These 73 - 76 A Bodies with disc brakes are the only ones with the 7 1/4 that got the larger 5 on 4 1/2 bolt pattern.
These axles are both in Excellent Condition and have no damage and no good wheel studs. The bearings feel fine but you may want to replace them to be sure.
These will retrofit to any Mopar A Body 7 1/4 rear end and would be perfect if you have converted to the larger bolt pattern front disc brakes.
These are 125.00 INCLUDING SHIPPING in the CONT USA. Canada and other International shipping would be more.
I accept paypal and credit cards over the phone.
Thank you very much, Steve Schweitzer
