Drackvan340
Active Member
Mopar M1 single plane 440 RB intake new in box never used $300.00, Ported 906 heads off B Body that ran 11.2 @ 118 mpg $500.00, 452 heads off 1971 440 TNT/ Magnum $250.00, 2 Rebuilt Carter AVS 750 cfm carbs: 4734S (1970 Cuda) & 4968S (1971 Charger / GTX) $300.00 each, 1 set of HiPo Exhaust manifolds off 1971 440 TNT/ Magnum $350.00, Hughes Engines Hydraulic flat tappet Cam, racing lifters and valve spring set: 237/ 242 duration @.050 and .548/ .555 lift New in box never installed $300.00, 727 440 trans and converter -Rebuilt 7 years ago $600.00, Mopar M1 single plane intake 340/ 360 Small Block $250.00, 1 Mopar A833 10.5 inch Small Block A Body Bellhousing $300.00.
