rustytoolss Well-Known Member Joined Sep 26, 2013 Messages 972 Reaction score 73 Location Clinton, Ohio Sep 26, 2021 #1 Does anyone know what brake pedal ratio mopar cars have with manual brakes, are all mopars the same ?
Kern Dog Build your car to handle. FABO Gold Member Joined May 23, 2010 Messages 9,851 Reaction score 28,384 Location Granite Bay CA Sep 26, 2021 #2 I did the math on it awhile back. It isn't hard to do. Take the length of the pedal arm from the bottom of the pedal to the hole from where it mounts and take the measurement from the push rod hole to the mounting hole and divide the two.
rustytoolss Well-Known Member Joined Sep 26, 2013 Messages 972 Reaction score 73 Location Clinton, Ohio Sep 26, 2021 #3 just wondering if all bodies A, B, C ,E FMJ were the same ?
Dana67Dart The parts you don't add don't cause you no trouble FABO Gold Member Joined Jul 16, 2017 Messages 15,015 Reaction score 12,359 Location Northern Colorado Sep 26, 2021 #4 rustytoolss said: just wondering if all bodies A, B, C ,E FMJ were the same Click to expand... Probably not. The size of the MC piston, wheel cyl., calipers weight of the car will all play into the equation
