ir3333
..back to the original post.
i once found a wire completely off a plug... (the boot was still on)
i don't baby the car and it never even had a miss when driven hard.
i use a mopar performance distributor (Mallory) through the stock 1 ohm ballast which
supplies about 8 .5 volts to the coil.
... all ignition components must be in good condition with good clean connections especially the bulkhead,regardless of what you use.
