btroxler
Part # P5007380. This is a 4 barrel intake for the 5.2 and 5.9 magnum style motors. It can be ran with a carb or have the injector holes drilled( you can see in the pic where the holes would go as I marked them ) and run fuel injection. I bought this as I was going to use a carb but decided to go fuel and found a manifold that was already drilled. This is a single plane high rise intake which is perfect for those stroker motors. It was port matched to my Edelbrock heads as well as all runners smoothed out. Asking 150 plus 20 shipped. Located in Chino Hills, Ca
