[Found!] Mopar magnum 4 barrel intake manifold wanted
Thanks for the reply, those will not work with magnum accessories. There are several threads here about the battles to use those Chinese intakes with magnum accessories. I am not up for that fight, I want to bolt on and go.
I am going backwards ( well maybe forwards ) from fuel injection kegger to carburetor and intake manifold and distributor. Something I can tune.
That's why I would like a M1 P4510018 intake manifold.
You didn’t specify so I listed the cheap intake.
Will the RPM work for you?
On that MoPar M1 dual plane…
Good luck finding that intake!
The eddy magnum will work and I may have to buy one, my preference is the Mopar M1.
There available I when I am not looking for one. My Luck!
I have a Mopar M1 duel plane, I bought new.
It has been run on 5.9 good intake, I might sell.
Message me.
I also have an M1 I ran on my motor for a couple of years. Sold it once and the guy complained that the ports were cast low and didn’t align, so I have it again. Appears they are about and 1/8” low when compared to the cylinder heads. Haven’t gotten around to re-listing it, but will at some point with the understanding that there are no returns and it will take a port match on both sides if max power is the goal.
